Disables the STP protocol on a particular STPD or for all STPDs.
| stpd_name | Specifies an STPD name on the switch. |
Disabled.
After you have created the STPD with a unique name, the keyword stpd is optional.
If you want to disable the STP protocol for all STPDs, do not specify an STPD name.
In an MSTP environment, you cannot delete or disable a CIST if any of the MSTIs are active in the system.
The following command disables an STPD named purple_st:
disable stpd purple_st
The following command disables the STP protocol for all STPDs on the switch:
disable stpd
